Error Message in console
  • Error Message in console
    Hello,
    happy to use Vray7. It's great.
    When rendering and when stopping Interactive Rendering the console opens and I get some error messages. I don't see any mistake in the rendering so far...
    Is it something where I need to take action?
    I am running the tonights nightly build on windows in R2025, as I had the same Bump node issue.
    The error came also before the nighlty build.
    Thanks!
    Hey haniel1107, this error is caused by a V-Ray plugin which was present with V-Ray 6 and was removed for V-Ray 7. Usually, the V-Ray installation should remove any such old files, but if you had problems with the installation (or installed manually) it is possible that this file would be present.
    In order to fix the errors, it would be best to first uninstall V-Ray 7 completely. Then make sure that there is nothing left in the "C:\Program Files\Maxon Cinema 4D 2025\plugins\V-Ray" directory. If the directory is still present after the uninstall, you should delete it manually. After that reinstall V-Ray 7 again and the problem should be gone.
    Deyan Hadzhiev
    Developer
    chaos.com
      Hi deyan.hadzhiev, many thanks! I will do so
