Vray 7 adds any node adjustment and C4D crashes
  • Vray 7 adds any node adjustment and C4D crashes
    In addition, after enabling node preview, adjusting parameters will cause c4d to crash
      Hi qingyuan_pang Could you please give us some additional information so we can assist you:
      1. Does it happen with every scene? Even a new, simple one?
      2. What is the exact Cinema version that you are using?
      3. Please, share with us the .bugreport file and the .dmp file so we can investigate them. You can see how to generate the .dmp file here: https://docs.chaos.com/display/VC4D/Creating+Dump+Files
      4. Share a videorecording of the crash so we can observe the exact moment. ​​
        The newly created simple scene will crash
        _BugReport.zip
          Thank you for the file! Please, be aware that all of the points above are vital and I would kindly ask you to answer them all.
            c4d 2025.1.1 vray 7.0
            _BugReport.zip
              Thank you, qingyuan_pang I have shared the files with the team and we will investigate further. I will reach back to you when I have more information.
                Could you let me know if you have an AMD GraphicsCard and if yes, what exactly is it?
                Additionally, please add the following Environment variable and test if the crash will appear again.
                VRAY_EXPERIMENTAL_NODE_PREVIEWS=0
                  My CPU is AMD 7950x with a core graphics card, and my discrete graphics card is 3090
                    Hi qingyuan_pang Thank you for your patience! The fix should be in the following Stable build ( 6th of Feb ). Please download it and test: https://nightlies.chaos.com/main#/vrayc4d7/stable/7.0
                    Let me know if it works as expected on your side.​
