Adding texture to vray Spot Light produces incorrect light fog effect
  • Adding texture to vray Spot Light produces incorrect light fog effect
    Click image for larger version  Name:	B.png Views:	64 Size:	192.3 KB ID:	1225233 Click image for larger version  Name:	A.png Views:	53 Size:	264.8 KB ID:	1225234 This is a comparison of the effects of Redshift and VRay, the effect of VRay should be incorrect
    Is there any news
      Hi 123456_, I confirm that the effect is incorrect in V-Ray and there seems to be no way of getting the expected results. However, using V-Ray GPU, produces the desired effect, so we will investigate on how to fix it for the regular V-Ray as well. I will log an internal issue for further investigation.
      Deyan Hadzhiev
      Developer
      chaos.com
        Thank you for informing me,I also found that Vantage does not support this light texture
