Chaos Scatter in folder won't render
  • Chaos Scatter in folder won't render
    Hello, I have noticed that if chaos scatter objects are placed in a folder within the C4D structure hierarchy, they will not render.
    can some one confirm that?
    Vray7
    Also can I ask to have a option to, when import objects from cosmos have the possibility to add node material or classic? the current node puts the viewport really slow...:/
    Hi nunomatos, thanks for bringing this to us.
    can some one confirm that?​
    It seems this is an oversight on our end, caused by the changes we did for optimizing the Chaos Scatter support. We will be working on a fix for this soon, but in the meantime, you can try using a simple "Cube" object (with 0 sizes) as parent of the hierarchy, instead of a "Null" object.
    We are also working on improving the viewport performance when multiple materials are added. We will however consider adding an option for this.
    Deyan Hadzhiev
    Developer
    chaos.com
      Hi Deyan
      thanks for the prompt answer and thanks for clarifying this
      best
      nuno
