Hey dearest community,
I found no resource for my issue so far online, so I'm here.
I have a 44 million particles from Houdini in an alembic. I tried render it with the vray particle route (importing the abc and point the vray particle object to the alembic object), the only issue is, that 44 million particles is way above C4D capabilities sadly. The render took ages, for no reason and the memory footprint was very very substantial(200GB+).
I found an other router, vray proxy. Importing the alembic via the vray proxy object works fine and the render is reasonable.
My only issue is, that I did not find any documentation on, what sort of data vray's looking for for attribute. What should be the name of a color data coming from Houdini, so Vray pick it up on particles rendered as a vray proxy, color, orient ect...
Thank you!
Thank you!
