Scatter on splines
  • Scatter on splines
    I want to create a hedge on a spline with scatter. One spline works fine but when adding more splines they seem to connect. In viewport it looks fine, in VFB it connects some way. Tried to reverse sequence, connect them but nothing seems to solve the problem. Anyone an idea?
    Hey, Ruby,
    Could you please let us know what you have in the scene file? Check the attached fil​e.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Hi Boyan,
      The problem seems to occur when importing old scenes into Vray7. Just tried the same as your attachment and that works fine. At first I thought it occured when using the edge to spline command but that works okay as well in the new version. So, it has to do something with the conversion I guess. When I create new splines the problem is gone. Thanks anyway!
        Hey, Ruby,
        Well, you can switch to the latest Scatter version: Select Scatter object -> Info -> Check Scatterversion.
        Cheers,
