After starting rendering in VRAY7, close the project file and reopen it. Once rendering is started, the software will freeze
  • After starting rendering in VRAY7, close the project file and reopen it. Once rendering is started, the software will freeze
    I have uploaded a demonstration video and engineering files of the problem
    My VRay version is this Click image for larger version
ID:	1227056 C4D version is2024.4.0
      At present, it has been found that there may be an issue with the rendering element of Cryptomatte, as once I add this rendering element and reopen the project, the rendering will freeze upon startup Click image for larger version
        Hi 123456_ Thank you for the report and the provided files. I'm looking into it and will get back to you here.
        Daniel Kapsazov | chaos.com
          123456_, Thank again for the scene. The issue has been reproduced and logged with our development department (VC4D-2680). I will get back to you once a resolution has been implemented.​
            Thank you for your reply. I hope it can be fixed as soon as possible
