Why does User Integer display an error when connected in this way
  • Why does User Integer display an error when connected in this way
ID:	1227309 Just like in the picture, I want to drive the displacement of the texture with VRAY_maGRAPH-INDEX, but it shows an error
    Hey 123456_, the inputs of the U tiling coordinate (which you have connected in the screenshot) can not be driven by another texture. You can only connect a constant node to it (e.g. the "Value" node). If you want to use the User Attributes to drive the tiling parameters, I suggest you to look for the Context nodes available.
    Deyan Hadzhiev
    Developer
    chaos.com
