Coloring nodes
  • Coloring nodes
    As shown in the figure, how can I color nodes in VRay
    By using the material ball conversion function, the correct connection method can be obtained Click image for larger version
      The method you mentioned is not feasible. The converted VRay nodes only have gradients and no noise
        Maybe your version is not VRAY7
          I will crash when using VRAY7, could you please take a screenshot to see if it works
ID:	1227431 Connect using this method
              Can I see what the result is
ID:	1227435 Just like this
                  This is great. Thank you very much
