Bottle Label perfectly aligned, but renders wonky
  • Bottle Label perfectly aligned, but renders wonky
    Hi! I've got a label wrapped around a bottle with spline wrap. Usual stuff. It's perfectly aligned in the viewport and wrapping as expected. Everything's centred. Problem is, when it renders it looks tilted and I can't work out what's wrong. It's more obvious when you see the type, but I've had to delete it for obvious reasons. I've tried baking the spline wrap to object, but no dice. I'll have to fudge it for time purposes, but I'd like to know what's happening here. (i'm on v6.20.01)
    Click image for larger version  Name:	Screenshot 2025-03-13 at 16.55.36.jpg Views:	0 Size:	258.9 KB ID:	1228866 Click image for larger version  Name:	Screenshot 2025-03-13 at 16.51.28.jpg Views:	0 Size:	623.2 KB ID:	1228867 Click image for larger version  Name:	Screenshot 2025-03-13 at 17.23.01.jpg Views:	0 Size:	1.04 MB ID:	1228871
    Hi KernitTheFont Please, share the scene with me so I can take a look. You can do it here or via our ticketing system: Submit a request
      Thanks Viktor, just PMed
      Also checked the UV map and label alpha and they're both straight and aligned too
Name:	Screenshot 2025-03-14 at 09.43.42.jpg
        Logged a ticket with the file. Thanks Viktor
