vr.scene
  • vr.scene
    there Would be great if we could already import vr.scenen from other programs, when that will be possible? And the export to Vantage would also be great for VR. Thank you very much
    Hello Wohnraumdesign ,
    Importing vrscenes to V-Ray for Cinema4D is in our to-do list but I cannot provide you with an exact time frame for that.
    Currently you can export scenes from V-Ray for Cinema4D but there needs to be added support for Chaos Vantage to read scenes, coming from V-Ray for Cinema4D.
    Aleksandar Kasabov
    chaos.com
      Hi there!
      However, support for Chaos Vantage needs to be added, where is this option to enabled?
      Thank you
        Hello,
        I am not sure I understand what you mean. Can you please elaborate on that?
        Aleksandar Kasabov
        chaos.com
          Cinema 4D export vr.scene wo wird for vantage Aktiviert?
            If you are asking how to do a .vrscene export from C4D - take a look here, but as mentioned here and also here there are currently some limitations
              Currently Chaos Vantage doesn't read vrscenes, coming from V-Ray for Cinema4D. This will be added with an update of Chaos Vantage in the future. You can find more information about this here.
              Aleksandar Kasabov
              chaos.com
                vrscene import into c4d will be valuable to our studio as well.
                thanks
                -DW
                -buck.co
                  thanks
                  It is with high priority in our to-do list since it's an important part of the interoperability between different V-Ray integrations.
                  Ivan Shaykov
                  chaos.com
                    Hello,
                    We just released V-Ray 5 for Cinema4D, Update 2 and with it we implemented the ability to import V-Ray scene files as reference objects. You can do that by going to File> Open Project, by dragging and dropping a vrscene in the viewport, or through the V-Ray menu> Geometry > V-Ray Scene. You can find more information about the V-Ray scene here.
                    You can download and install the build from here. You can also check this forum thread for more information about the release.
                    Aleksandar Kasabov
                    chaos.com
