LUT files in Cameras
  • LUT files in Cameras
    Would it be possible to insert LUT`s in the CA Object (like Octane) - this would help a lot.
    Hello acidnoid,
    You can load LUT files in the Layers panel in the VFB2 and save the image with the applied color transformations. You can find more about that here.
    Can you share information about your workflow and why you need to add LUT files inside the camera object? Thank you.
    Aleksandar Kasabov
    chaos.com
      Hi Aleksander,
      VFB I know - useful - sometimes I have different perspectives and would like to use different LUT's - if I could save them per Scene in the Cam settings would be quite handy - as I would have otherwise to load for each cam a new VFB setting - switching Cams would be easier.
      Thank you.
        as far as I see the VFB is in general limited to post editing single renderings
        In Corona most VFB settings are overrideable with per camera settings for batch rendering
          Hello,
          Thank you both for your feedback. I will forward it to our developers and we will discuss if and how this could be implemented in the future. Thanks.
          Aleksandar Kasabov
          chaos.com
