V-ray 3.7 converter
  • V-ray 3.7 converter
    Hello guys
    can we make a request to see if is possible to implement on v-ray converter old scenes?
    - is possible to convert the normal map bump to the new normal map shader? everytime I convert a old scene that use the normal map, I need to manually convert to V-raynormal shader
    - is possible to convert the variation shader (c4D) (the colour field/textures) to a V-rayMultiSubTex shader?
    - is possible to convert 3.7 VrayDirt shaders to Vray5 dirt... at least the texture channels to avoid we loose them on the conversion...
    this could be awesome
    thanks
    nuno
    Plus a coverter from standard Cinema Materials to Vray.. like in 3-7...
    Was not perfect, but good enough to save a lot of time... Manual adjustments are certainly
      Hello,
      Apologies for the delayed reply.
      I have added the suggestions for the V-Ray 3.7 scene converter in our internal system so our developers can have a look. I will let you know once we have more information on the matter.
      We are planning on implementing a converter for native Cinema4D materials in the future.
      Aleksandar Kasabov
      chaos.com
