Is there a plan to add VRayScatterVolume material
This topic has been answered.
  • Is there a plan to add VRayScatterVolume material
    This material can be used to quickly convert models into volume clouds
  • Answer selected by zhanet.georgieva at 15-08-2023, 10:48 PM.
    Hey 123456_,
    Since V-Ray 5 Update 1 (noted in the changelog from in the link) we integrated the V-Ray Scatter Volume material inside the V-Ray material. You can use it by going in the Refraction group in the V-Ray material and under the Translucency tab set the Translucency type to Volumetric and start playing with the various parameters until you achieve the desired effect.
    Here is a quick example I made for you that could be used as a starting point (IOR should be set to 1):
    Click image for larger version  Name:	clouds_volume_scatter.png Views:	0 Size:	1.12 MB ID:	1188609
      Hey 123456_,
      Ivan Shaykov
      chaos.com
        Originally posted by shaio View Post
        Hey 123456_,
        Thank you for your reply. It was my negligence
