Are there any plans to add these features to Vray GI, just like Max's
  • Are there any plans to add these features to Vray GI, just like Max's
ID:	1209615 This way, the environmental colors in the indoor environment can be easily processed
    Hi, there are no plans on adding these GI modification options. The reason is mostly because they add additional bias to the GI, and may easily lead to other unexpected problems and render results.
    Deyan Hadzhiev
    Developer
    chaos.com
      Thank you for your reply. What I want to say is that although this feature has caused bias and may result in inaccurate results, some effects may be that I hope it is not so accurate. For example, in an indoor room with a yellow wall, I don't want the items inside to be affected by the yellow wall so much. So, I can lower the saturation of the GI to achieve my goal.
        Hi, you have several ways to get rid of the color bleed, for example you can use an override material or you can desaturate the GI channel in VFB composite mode.
        3D Scenes, Shaders and Courses for V-ray and Corona
        NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
        @3drenderandbeyond on social media @3DRnB Twitter
          Yes, I know these methods can work, but it's more convenient to directly modify the GI saturation
