Post translate support
  • Post translate support
    Nightly builds from tomorrow will contain Python "Post Translate" support (ROP -> "Post Translate").
    It's similar to https://docs.chaosgroup.com/display/...ed+V-Ray+Scene, but is based on AppSDK Python binding.
    WARNING: AppSDK Python binding gives you FULL control over the rendering process so be very careful.
    I've added some restriction in VRayRenderer() object creation, but still a lot of methods are available.
    I'll try to limit methods available for "post translate" in the future.
    Check some docs about AppSDK:
    * https://docs.chaosgroup.com/display/APPSDK
    * https://docs.chaosgroup.com/vray_app...n27/index.html
    Some simple examples:
    List scene plugins:
    Code:
    import os
    import vray
    from vfh import vfh_utils
    with vray.VRayRenderer() as renderer:
        for plugin in renderer.plugins:
            vfh_utils.logInfo('plugin ' + plugin.getName() + ' (class ' + plugin.getType() + '):\n')
    Change color:
    Code:
    import vray
    r = vray.VRayRenderer()
    p = r.plugins["|mat|vrayMaterialBuilder|vrayMtl"]
    p.diffuse = vray.AColor(0, 1, 1, 1)
    If you are not using installer you may have to modify your .json or .env to include path to AppSDK Python binding.
    For json it may look like that:
    Code:
    { "PYTHONPATH" : "${INSTALL_ROOT}/appsdk/python27" },
    andrei.izrantcev@chaos.com
    Support Request
