How to set up ACEScg with V-Ray for houdini?
  • How to set up ACEScg with V-Ray for houdini?
    Hi guys,
    Is there any reference for how to set up OCIO and ACEScg with V-Ray for Houdini?
    Thanks
    Steve
    Sure. You can do it 2 ways. System wide with enviroment variable name OCIO or just Houdini enviroment variable.
    Attaching image of windows env variable, you just basically need to add/set OCIO and point do the config file.
    Second option is just Houdini, that can be done for example with package files, see official docs on what they are https://www.sidefx.com/docs/houdini/ref/plugins.html
    Basicaly with packages file you can load config per json file copied in your \Documents\houdini17.5\packages .
    Attaching my example file. Just edit the path in json file to where you have your OCIO config. Then save the file to \Documents\houdini17.5\packages\Ocio.json
    Sorry for ziping the json, forum does not allow attaching of .json files
    Good luck!
    Noemotion.net - www.noemotion.net
    Peter Sanitra - www.psanitra.com
    Noemotionhdrs.net - www.noemotionhdrs.net
      And what about the OCIO setup in VFB ? how we do work with it ?
      GHiOM = Guillaume Gaillard
      freelance 3D artist
      www.ghiom.com
