Material with Bump Map Setup Question
  • Material with Bump Map Setup Question
    Noob Question: Could someone please help me with setting up basic material with a bump map in Houdini? And material in general?
    In 3dsMax you just plug a bump map into the material, but in Houdini i cannot figure it out.
    VFH docs page says "Simply connect a material into the BRDFBump node to add additional bump or normal map functionality." Where does the actual texture file plug into and then where does all that plug into?
    Is it possible to get some examples please?
    Thank you
    screenshot:
      You are missing the material output node. Do it like this:
      Noemotion.net - www.noemotion.net
      Peter Sanitra - www.psanitra.com
      Noemotionhdrs.net - www.noemotionhdrs.net
        Ah got it, thank you!
