Nightlies Zip installation package does not include the Launcher batch file.
  • Nightlies Zip installation package does not include the Launcher batch file.
    A recent Nightlies Zip installation package does not include the Launcher batch file.
    Is there any reason?
    How do I use the Zip installer version?
    Best wishes,
    Yuji Yamauchi
    OakCorp Support
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hello, flat ,
    You could use the installer instead, in case using the zip is not a necessity.
    If you prefer to use the zip install, here's what you need to know:
    We removed the .bat file and added a README.md file in the docs folder explaining how to set up either an environment file under the Documents/houdini folder, or a vray_for_houdini.json file under the Houdini install folder/packages.
    Both will give you the same result. The difference is that the packages approach allows you to separate the required variables for each 3-rd party plugin you're using in Houdini into a separate json file, while the environment file in the documents folder has to contain all the paths in the same place.
    The installer we ship will set you up with a json file. I'm also attaching an example environment file you can place under documents/houdiniXx.X - use either one or the other but not both.
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Thank you for the details.
      It was helpful.
      vray_for_houdini.json package installation is convenient.
      Best wishes,
      Yuji Yamauchi
      OakCorp Support
      oakcorp.net
      v-ray.jp
