Dome Light HDRI based and OCIO
  • Dome Light HDRI based and OCIO
    Hi, I have a question about proper HDRI lighting with ACES workflow. I have HDRI that in linear worspace, as I know, I need preconvert HDRI for using in ACES workflow. But can I load my HDRI as V-ray Image file in MATNET, with Colorspace set Linear, and convert it inside Houdini using OCIO? When I do it, lighting became a lot darker. Please see screenshots attached for setup.
    Hey Mikhalenko ,
    what is the Color Space under Renderer -> Color Mapping ?
    gosho.genchev@chaosgroup.com
      Hi. it was sRGB, I have not seen this option I swithed to ACEScg and also I'm totally forget about UV in VrayImageFile, I have changed it to Enveronment, and eveythig started to work like if I load HDRI directly to Dome light.
      Thank you
