EXR Custom Metadata
  • EXR Custom Metadata
    Does anyone know of a way to get custom metadata into the EXR headers on a frame by frame basis? Lets say you wanted to write the position of an object in there with it changing every frame.
    Hello Dubbie99 , I'm not sure how you are trying to set the metadata, but you could do it directly in Render ROP > Images tab > Image Format > Extra Attributes, with Pre-Frame Script or with a Post Translate. In any case if you are rendering on a farm or Standalone via vrscene, the vrscenes should be exported per-frame.
    This scene contains an example for every of the methods above.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Thankyou Chakarov, very helpful.
