vray image file loader
  • vray image file loader
    Hey guys
    So im loading in an image sequence/texture sequence via the imagefile loader - but no matter what numbers or expressions i try under the sequence frame number and offset inputs - nothing happens. Am i missing something here?
    Seems to work here. I'll need more info about your system, OS, Houdini and V-Ray build numbers. Also a scene with the problem will help a lot.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Hm interesting. thanks for checking.
      windows 10, houdini 17.5.173 with 41203 houdini17.5.173
        Well this is a very old V-Ray /4.12.03/, current builds are 4.30.03. There were similar issue some time ago, may be with that V-Ray core. Updating your V-Ray to last build should fix the problem.
        www.chaosgroup.com
