(Resolved) Using masks generated in SOP's as masks in material?
  • (Resolved) Using masks generated in SOP's as masks in material?
    Complete newbie question: I've used VRay (Max, Maya) for many years, but I'm finally trying out Houdini. I'm doing a procedural landscape that has a lot of heightfield masks in the SOP, and I'd like to use them in different ways in the material. How can I do that? I found solutions for Mantra and Redshift, but those seem to be specific to those renderers. Any help appreciated.
    You generate geometry in SOP - it's information written on attributes of the points, vertices or volumes, like maybe in your case with height fields, which are a 2D volume. To use this in the shader, you need to call that attribute, one way is using the vray user color node, it has attribute options. I think you can't render the height field directly yet, you gotta convert to a mesh first.
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
      Thanks. Like I said, I'm a complete newbie when it comes to Houdini, would you possibly have an example of how that works? I can render the heightfield in VRay, I just need to access the masks from the SOP.
        like glacierise said highfields are 2D volumes. Unfortunately there is no way, for now, to use them directly. But when convert the heighfield into a poly object, Houdini will promote the mask volume as float point attribute. Check the example bellow.
        Georgy Chakarov | QA
        www.chaosgroup.com
        georgy.chakarov@chaosgroup.com
          Thank you! I've been trying different things for days, but I never put the material network in the SOP before. One last question: this only promotes one mask - how can I get several masks?
          Edit: nevermind, heightfield_copylayer->edit that layer worked. Thanks again.
