(Resolved) AppSDK: Append VRScene file using namespace
  • (Resolved) AppSDK: Append VRScene file using namespace
    Is it possible to add a namespace to the content of vrscene files loaded with vray.VRayRenderer.append("file").
    We are running into issues with duplicate node names.
    Best,
    Jacob
    Jacob Børsting
    Head of Pipeline @ Ghost VFX
    Use .appendFiltered(): https://docs.chaosgroup.com/vray_app...appendFiltered
    andrei.izrantcev@chaos.com
    Support Request
      So how would I use this function if I want to add a namespace to all nodes in a vrscene file?
      Jacob Børsting
        Code:
        import vray
        def onFilterPlugin(r, className, pluginName):
          print(className, pluginName)
          if className == 'Node': # is it a Node?
            return 'namespace' + pluginName #create the plugin with a different name
          return False # skip other plugins (or return True if you don't want to skip or rename)
        with vray.VRayRenderer() as renderer:
          renderer.appendFiltered('file.vrscene', onFilterPlugin)
          # print the names of the plugins held in the renderer
          i = 0
          for plugin in renderer.plugins:
            i += 1
            print(str(i) + '. ' + plugin.getName())
          Thanks.
          It works great.
          Jacob Børsting
