(Resolved) Noob question. Scatter lights to points.
  • (Resolved) Noob question. Scatter lights to points.
    Hi guys, I'm really having difficulty figuring this one out,
    lights live in the OBj level, but how can i scatter them to points that live inside a geo?
    many thanks!
    x570, 5950x, 96gb Ram, Gigabyte Turbo RTX 3090, Asus Turbo RTX 3090, 2x Samsung 970 Evo SSD 1.0TB M.2 NVMe , 1000 corsair + 750 corsair PSU's. houdini 18.5 . vray 5.1
    Hey,
    Just use an "instance" node. Merge your points into the instance node and use the light as the instance source.
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
      Thank you i did this inside the instancer.. is that correct?
        No need to copy more points to it again. What's coming from your "../../torus1/lights"? Poligons, points? You can use them straight away. Even geometry, because it has points too.
        Just make sure you set the instance node to "Full Point Instancing" or "Fast Point instacing" to see it in the viewport. Even with the Point instancing set to "Off", they will render.
        Best,
        David.
          Thank you so much David.
