(Resovled) Batch rendering multiple camera
  • (Resovled) Batch rendering multiple camera
    Is there any way to batch render multiple camera? I can't find any info in the help.
    make muliple rops with different camera or use takes
      Hey creac ,
      as Ronald has stated in the post above mine, at the moment the simplest way to do this would be to use multiple Renderer ROPs.
      Hope that helps!
      gosho.genchev@chaosgroup.com
        Hi, how do you setup multiple rops with different cameras for batch rendering? I have got an error message...
          imho the IPR node is kinda irrelevant - you can shift click on the IPR shelf button to choose which vray rop to get rendered.
          Hristo Velev
          MD/FX Lead, Bottleship VFX
          Sofia, Bulgaria
            glacierise noted, but then I can't batch render - I have to choose between cam1 or cam2. Is that correct?
              Hey creac ,
              You shouldn't be piping the Renderer ROPs into the IPR ROP but a Merge ROP instead. That should do it
              The purpose of the IPR ROP is internal - it has to be present for the IPR to work but as glacierise mentioned - you can switch which camera is used in the VFB itself.
              Best regards!
                Gosho.Genchev awesome! Thx
