(Resolved) VRay Viewporttex
  • (Resolved) VRay Viewporttex
    hi, I tried to use vray viewporttex to display texture in the viewport.
    quick shader was fine but viewporttex didn't work as expected, nothing showed up.
    what's the proper procedure to use viewporttex?
    cheers
    Hey cao_hien ,
    I believe the HDA needs updating after some changes we made to the V-Ray Material builder.
    Could you please check if assigning a V-Ray Material Builder and using the Viewport options in its parameters to select a texture to display is convenient for you ? Meanwhile we'll look into the issue with the ViewportTex HDA.
    Best regards!
    gosho.genchev@chaosgroup.com
      Hi cao_hien , seems to work on my end, V-Ray Viewporttex supports only V-Ray Material Builder
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
