Multi exr
  • Multi exr
    Hello.
    I chose Write Multi-part Exr. But all my render elements still save as separate files. Especially it's not good for Cryptomatte, as I can't use it in Nuke, or I can somehow merge all necessary cryptomatte chanels in one to use correct cryptomatte?
    Is ${AOV} tag present in filename, if so just remove it.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Ok. Thank you. I'm also found that when I use LightMix it's save only 1-st frame , other frames are not saved
        I'll check this LightMix issue. Thanks Mikhalenko !
        www.chaosgroup.com
