One triplanar for multiple ImageFiles
  • One triplanar for multiple ImageFiles
    Hello!
    I'm coming from 3dsMax and I'm wondering if in Houdini there's the option to use one triplanar node to map multiple ImageFile nodes like we have in 3dsMax.
    I'm trying to make the switch to houdini but I'm finding the Vray for houdini documentation is very poor and lack of examples.
    It would be great if we can see some screen shots of node layout for some operations to make things more clear...
    www.gaell.com
    There is a Triplanar node with inputs per-axis.
    andrei.izrantcev@chaos.com
    Support Request
      The only way to use "one triplanar" with many ImageFiles is to reference copy it. RMB over V-Ray Triplanar > Actions > Create Reference Copy, this way all copies will share same settings, but different inputs.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Yes, thanks Georgy, thats what I wanted.
        But I still wonder... if we have an uwgen input in the image file node why does not exist the possibility to feed this input with the uvs from the triplanar node like we can do in max.
        Is it that complicated?
        Your method is perfectly fine for me but is just that I find the other way more "elegant".
        www.gaell.com
          V-Ray in 3dsmax do the same under the hood
          www.chaosgroup.com
            Good to know
            Thanks!
            www.gaell.com
