Vray Sky Overrides incomplete?
  • Vray Sky Overrides incomplete?
    Hello again,
    I have a problem: I need to darken a Vray Sky quiet a bit and keep the lighting of the scene intact. So I set the Vray Sky override in the environment setup (as the intensity of the sky is linked to the intensity of the Vray Sun in its node)...
    But now here comes the thing: I also need to have a horizon little bit lower - where I use Horizon Offset angel parameter of the Vray sky. But this parameter is being overriden by the new Vray Sky environment node but in the same moment I lack access to change it.
    Am I something missing or is there way how keep the control of both parameters?
    Thanks!
