(Fixed) [HOU-2515] PSA: Global No Bitmap Override
  • (Fixed) [HOU-2515] PSA: Global No Bitmap Override
    Hi everyone,
    Warning to all of you updating V-ray to a recent nightly build coming from an older build.
    In the recent builds the "Global No Bitmap Override" have a checkbox does comes disabled by default now, this makes it that all bitmaps that are missing will not be overwritten by a black color anymore (before all missing maps got a black color), the problem with this is that when artists add an environment node in an OUT context to add a fog for example, that environment node comes by default with an empty image node which before caused no problems because that global "Global No Bitmap Override" made it render black, but now your renders suddenly start having gray color through the mattes.
    Default Color on image nodes when no image is found:
    Click image for larger version  Name:	default_color.JPG Views:	33 Size:	18.6 KB ID:	1109998
    Default image file in environment nodes:
    Click image for larger version  Name:	default_env.JPG Views:	19 Size:	53.1 KB ID:	1109999
    Result on matte objects of the missing bitmap in the environment node:
    Click image for larger version  Name:	matte.JPG Views:	19 Size:	58.9 KB ID:	1110000
    Gosho.Genchev, the default environment node should come with a color node set to 0.0.0 and not an empty image node.
    Hope this info can help someone else, as this cost us quite a bit of time hunting for this today.
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
    Thanks for the info. Very good to know.
      david.anastacio Both the bitmap override and it later being off by default where both feature requests from me. I think this is the most logic default and it matches also vray in other software. Though i agree that I rather have black then grey in default color be default on the image file node
      Regards Alexis
      http://goodbyekansasstudios.com/
        Regards Alexis
        Hey Alexis,
        The checkbox change is ok, and it being in line with the other DCC's makes sense. The part that's annoying is that it messed up stuff that's working and makes us lose time hunting for the problem.
        This is easily fixed by that default color of the image node to be black instead of gray....why is the default gray? why?
        Best,
        David.
          david.anastacio haha, yeah that i dont know :P
            Hey all,
            The Default Color is updated to black now.
            Best regards!
            gosho.genchev@chaosgroup.com
              Gosho.Genchev thanks gosho!
                Originally posted by Gosho.Genchev View Post
                Hey all,
                Best regards!
                That's great thanks.
