Color Mapping Parameters
  • Color Mapping Parameters
    Hi ,
    it seems that the documentation for the Color Mapping Tab is not adjusted for the Houdini Version
Name:	Screenshot 2021-10-01 103424.png
    In houdini there is no burn value. So how do I adjust the blend between reinhard and linear color mapping mode?
    And also the Colors Multiplier do have an effect on the rendering when reinhard is selected even though they shouldn't as in the help specified.
    Can someone clear this up for me?
    Greetings Lucca
    the idea for last few years is that you do your tonemapping in VFB and leave those settings (Color Mapping) on defaults.
    Marcin Piotrowski
    youtube
      We do not use the VFB for grading/tonemapping for now. Btw. are the settings of the VFB respected if you later render your images without buffering them to VFB?
      It would be nice to know how the parameters in the rop in fact do affect the image since they apparently do different things then the help says.
        They are even stored in the vrscene file.
        They are not doing different thing.
        We have to adjust labels in the docs sections though (since we don't change labels dynamically yet...).
        andrei.izrantcev@chaos.com
        Support Request
          Oh thats interesting I didn´t know that.
          which parameter controls the blend value at the moment when using reinhard Mapping?
            "Bright Colors Multiplier". I'll rename this parameter to "Bright Mult. / Burn Value".
            Support Request
              >I'll hide dark mult if Reinhard is selected and rename parameter to "Bright Mult. / Burn Value"
              While doing that can you please double check.
              The picture below is rendered with exponential color mapping. The region on top is rendered with reinhard "bright colors multiplier" set to zero. Which should blend 100% to exponential right? But the result looks different.
                "if Burn Value is 0.0, the result is exponential-style mapping"
                Well, docs say "exponential-style" not "100% as Exponential mode".
                It's the same in 3dsmax, so I guess this is how it works.
                Support Request
                  Reinhard with burn 0 = Exponential in 3ds max.
                  also bright/dark colors multipliers were always separate controls from burn.
                  Marcin Piotrowski
                  youtube
                    Ah. I indeed expected "exponential-style" and "exponential mode" to be the same and never did a comparison between them in max back then.
                    Thanks for the hint.
                      piotrus3333, well, I've tried it in 3dsmax and it's not 100% the same, could you pls double check it?
                      Support Request
                        I did also double check it. Its not the same on my end.
                          you are right. something is wrong with Exponential in Color Mapping settings. Burn = 0 in both the settings and VFB give the correct result y=x/(x+1).
                          Marcin Piotrowski
                          youtube
                            it must be a bug. there would be no point in changing this suddenly.
                            Marcin Piotrowski
                            youtube
