I tried to look up the docs but I couldn't find any info there. Not 100% sure what this node does? Is it like a bind and bind export from vop network? and if so I would like to see an example of how it can be used. It didn't work for me. Thanks!
[HOU-3206] aovBind Node
Tags: None
Here is an example scene. Basically you connect some texture to the input, entering a name and then setup ROP -> Images -> AOV Binds.Attached Files
Well the main difference is that AOV setup at the material output will produce render elements no matter what, while with AOV bind only the ones selected at the ROP node will be rendered..Last edited by bdancer; 15-06-2022, 06:23 AM.
- Likes 2
I'll need a hip file to check, may be it's some specific setup that doesn't work - could you please send me the .hip file?
of course
actually, in this example, I can't get any approach working, maybe I do smth wrong
basically, I try to export an attribute my_noise to an AOV which
houdini 19.0.561
vray 5.20.20
windows 11Attached FilesLast edited by dev_l; 16-06-2022, 02:16 PM.
This seems like GPU regression, we'll have to fix this. CPU works correctly.
