disable camera MB
  • disable camera MB
    Does anyone have any tricks for disabling camera motion blur for a particular object?
    I am using the new spark SOP which has baked in camera MB.
    I have tried a bunch of things but nothing has quite worked right.
    I'm reluctant to render as a separate pass because there are a bunch of other objects in the scene that occlude the sparks, so I'd really need to use deep to composite properly.
    You want all motion blur off , not only camera motion blur right? But I'm guessing as it is a deforming geo and you disabled velocity it has no geo (deform or transform) motion blur already, only camera.
    Have you tried setting the geo sub steps of you sparks to 1 via the V-Ray object properties?
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
      yes I tried that.
      I also tried computing the inverse camera MB vector for each point, but I'm not sure I got my math right.
        Hey Dubbie99 ,
        At the moment we have no per-object control for camera motion blur specifically. I've tried doing exactly what you mentioned in your last post - bringing the camera in with an Object Merge, inverting the transform and generating velocity pointing in the opposite direction. It seems to work for me in my simple test case - could you please take a look and see if it helps for your scene as well?
        Scene -> Link.
        Best regards!
        gosho.genchev@chaosgroup.com
          Hi Gosho.Genchev
          Thankyou for your example. I don't think your method can possibly work.
          If you consider this picture:
          The velocity of Point A and B is both {0,0,0} in world space.
          The camera matrix difference is identical for both points A and B, and yet they each have a radically different velocity vector.
          I think that it is essential to compute the vector in screen space.
          My idea for an algorithm is this:
          Get p_curr in screen space
          Get p_next in screen space
          vec = (p_curr - p_next) * 0.5
          project vec to world space
          I just need to actually get it to work haha
          Thanks for your help anyway.
            After tying my brain into a pretzel, I finally solved this and it was simpler than I thought.
