(open) [HOU-3183] Exclude object from reflection \ refraction in other objects
  • (open) [HOU-3183] Exclude object from reflection \ refraction in other objects
    How do I exclude an object from reflecting and refracting in some other objects?
    I have a "reflection card behind" a glass bottle and I'd like it to affect only the bottle and the liquid but not the rest of the scene.
    It was controlled per object in 3ds Max via Trace sets. Can't seem to find this option in houdini.
    We use standard Houdini controls for that, there are "Reflection Mask" and "Refraction Mask" parameters under "Render" -> "Shading" tab.
    andrei.izrantcev@chaos.com
    Support Request
      Thank you Andrei,
      Adding objects to the list does not do anything by itself. Do I need to turn something ON in Vray settings to make it read these parameters?
        OK, it works on CPU but does not work on GPU. Is it a bug or not ready yet?
ID:	1148799Click image for larger version
          Hi soviet_post
          we have a request in our system about this, I will check the status with our developers
          Best,
          Muhammed
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
            Thank you Muhammed!
