GPU sample limit
  • GPU sample limit
    How do I limit amount of samples per frame using GPU? Can't find Samples Limit in Houdini, here is a screenshot from 3ds max.
    Already emailed to support but hoping for a community wisdom in case if I just simply overlooked the settings.
    Thanks a lot
    Hi soviet_post
    Samples Limit parameter is specific to the GPU UI in 3Ds Max, this is how it is calculated internally
    Max Subdivs = square root of samples limit + 1
    If you use around 70 max Subdivs in Houdini, you get an identical result to 5000 Samples limit in 3Ds Max.. In reality you only need like 50 Max Subdivs for V-Ray GPU, keep in mind that Max Subdivs has a big impact on performance
    And you can set the min Subdivs to 8 in houdini, which is what Max uses by default
    We are going to change the GPU UI in Houdini soon to be similar
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
