mixed OS Distributed Rendering path mapping?
  • mixed OS Distributed Rendering path mapping?
    Is there a way to specify path mappings for Distributed rendering across different OSes?
    I have a linux workstation and a windows GPU node. I was trying to keep it in windows since I remote in and use photoshop and c4d on occasion when projects require it.
    I'm looking forward to this also, Windows for the workstations and Linux on render nodes. The only solution I found is to check "Transfer Missing Assets" but when working with large sims it gets complicated.
    EDIT:
    I found in the docs that you can create a remapPathFile XML file and set it in when you run the vray -server. In my case I added all the Windows letters and mapped to /mnt/sharedfoo
    https://docs.chaos.com/display/VNS/V...d+Line+Options
