animated vrayScene with motion blur
  • animated vrayScene with motion blur
    Is it possible to render an animated vray scene with motion blur?
    Hello Jon3D,
    Could you please send us the scene so we can investigate further? You could upload it through our support contact form if it is more convenient for you.​
      Do you really need a scene file for that? I can make one later but right at the moment there is no time for it on my side. I did expect that you can pretty fast check it without a scene file in this case.
      1. create simple sphere or some kind of geometrie
      2. safe it as a vray scene
      3. import the vray scene
      4. animate it with transform node
      5. render it with vray physical cam with mblur ticked on - > problem: mblur will not show up
      kind regards
      Jon
        Only if you activate "Use Rayserver Instancer" (but it will load only geometry in this mode, no lights).
        andrei.izrantcev@chaos.com
        Support Request
          Ah with rayserver instancer. Nice. Are there any other limitations than lights we should be aware of? Materials are supported?
            Only geometry will be loaded in this mode (no light, no volumetrics).
            Yes.
            Support Request
