Noise from Max to Houdini
  • Noise from Max to Houdini
    Hi!
    I try to convert some materials from our Max Database to Houdini and several materials have noises. In max the noise has the "size" parameter which defines the size of a "single noise splodge" in scene units.
    In houdini, vray noise has this "frequency" parameter to control the size of the noise splodges.
    Now my question is, whats the best way to match the "size" parameter from max with the "frequency" parameter in houdini? Is there any formula or any hint from you, how to do this properly?
    Thank you and greetings!
    Have you tried exporting material from 3dsmax into the vrscene file and then importing in Houdini?
    andrei.izrantcev@chaos.com
    Support Request
      Ohhh! Alright. Now I see, there is "VRay TexNoiseMax" which comes with a vrayscene. So I will use this one. Thank you!
