Changing frames used in animated image texture?
  • Changing frames used in animated image texture?
    Probably a stupid question--I have a two-frame image sequence for a texture, with frames 1 and 2 in the file names. If I see them at frames 1 and 2 of the shot, they work as expected. I don't want them to switch until frame 357, though, and none of the frame override fields seem to be doing anything--I think I've tried every option and number except ping-pong and frames 1 and 2 are great but everything is black afterwards. (I don't want to convert this to a 900-frame image sequence of just two images.) I assume it'd be range, start 1, offset 356, speed 1, length 2, but I can't get those or any other combo to work. Any help is appreciated.
    I guess you could hack this by adding geometry attribute like <my_frame> (of type string) and set it to whatever value you need and then use this tag instead of frame tag in the image file path.
    andrei.izrantcev@chaos.com
    Support Request
      Where would I reference that in the image node? How would that be different than the many, many numbers I've been manually typing in?
        You don't need to type many many numbers, you could use attrwrangler/VEX adding primitive attr:
        Code:
        if ($FF == 1 || $FF == 2) {
            s@my_frame = "00${FF}";
        else if ($FF < 357) {
            s@my_frame = "002";
        else {
            s@my_frame = "001";
        You'll also need to force "my_frame" attribute via "V-Ray Object Properties".
        Support Request
          Perfect, thanks! I was crashing at first, but found out that trick apparently doesn't work with GPU rendering. (That's okay, CPU is actually faster for this project anyway.)
