Hi Guys,
Been reading through a lot of the posts here and Chaos devs seem to be pushing Alembic as the preferred file format. I'm ok with that but I have one issue I need to resolve in order to be able to use it instead of vrscene in my workflow.
I'm using vrscene as a proxy for assets like vegetation and I like how it lets you reduce the viewport poly count on a mesh. How do you do that with Alembic, there is no Viewport Preview Faces limit option.
Also by the way Alembic is about 75% larger file size than vrscene.
And finally, vrscene export via Vray render node in /out is broken, doesn't let you export as vrscene in the latest nightly. (Well it exports and makes the file, but when you bring it back in its blank)
Vray - vray_adv_62005
Houdini - FX 20.0.547
