Why can't I create a Vray BitmapBufffer node from the TAB menu in a MaterialBuilder?
  • Why can't I create a Vray BitmapBufffer node from the TAB menu in a MaterialBuilder?
    Why can't I create a Vray BitmapBufffer node from the TAB menu in a MaterialBuilder? Also, why can't I create a V-Ray TextBitmap node from the TAB menu in a MaterialBuilder? What is the philosophy here?
    Hey colin_hannon ,
    The BitmapBuffer is a container (with some extra parameters) for the file on disk. You then need a UV Generator, and a TexBitmap to apply the texture in your material.
    We opted to simplify this process with the V-Ray Image File VOP - under the hood, it generates the BitmapBuffer, the UV Generator, and the TexBitmap nodes.
    Best regards!
    gosho.genchev@chaosgroup.com
      Why do you need to create those manually? There is image file node.
      andrei.izrantcev@chaos.com
      Support Request
