VRAY object properties for volumetrics not working as expected
  • VRAY object properties for volumetrics not working as expected
    Hello, I would like to know what is the proper way to matte out different volumetrics for comping/rendering purposes instead of rendering all together.
    Currently i have tried using vray object properties as per the houdini docs but it seems that it works only for geometry. Using a wrapper material override does not matte out the volume correctly as well.
    What might be the proper workflow to matte out volumetrics?
    Cheers,
    Bryan
    Hello cg_dandelionstudios ,
    Treating volumetrics as matte surfaces is currently not supported in V-Ray. The development team is in the process of overhauling volumetric rendering for the next version of V-Ray so expect that to come to V-Ray over in the mid-term future.
    Currently, the recommended workflow is to use Cryptomatte to generate a mask.
    Best regards!
    gosho.genchev@chaosgroup.com
      Gosho.Genchev Does this mean that they might overhail the volume shader as well?
      Sometimes I need to try to match mantra looks in VRay and find it impossible. One thing I find a struggle in VRay is getting the volume to respond to intense lights inside of it predictably.
        Hey Dubbie99 ,
        Yes, exactly.
        When you say "predictably" - would you mind elaborating further, or maybe sharing a couple of images that illustrate the problem?
        Best regards!
