How can i Set or Change the Out node i see through VFB?
  • How can i Set or Change the Out node i see through VFB?
    hi.
    i have sevral V-Ray Render output in Out tab, and each of them has different render elements settings, force object settings and i want to check them one by one.
    is there any way to change target of VFB() to selected Out node?
    the way i found is to hit the "Render to Disk" in the out node i want to check and stop, and its replaced to selected out nodes path.
    everytime i render the out node, the target of the VFB is changed to the out node i just rendered,
    but as i used different force object settings for each out node, i might want to lock the default out node for VFB(the out node named vray) so theres no confusion.
    so my question is,
    how can i set or change the out node i see through VFB?
    Click image for larger version  Name:	Screenshot 2024-11-13 112313.jpg Views:	0 Size:	37.1 KB ID:	1220205
    You just need to select the vray render rop and go to images show vray frame buffer. For each modification you treat it as a new render rop, so in effect a rop is your render layer.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      thats what i was looking for.
      thanks a lot!
        Another way of doing it which may be faster is this:
          It would be great to have a drop down menu in the VFB to select the ROP you want to render
          www.gaell.com
            Each ROP has it's own VFB so it's not possible atm.
            andrei.izrantcev@chaos.com
            Support Request
