"Import Material" error message
  • "Import Material" error message
    hi,
    I wanted to import vray material from modo V-ray scene. ( can we do that ? )
    I have made a cube and apply an v-ray material.. , i have exported a .vrscene and try to import in houdini.
    When i importini i see my material under the plugin tab , when i click import i have this error message.
    Calling: vray_import_material D:/Untitled2.vrscene
    VFH [Error] * Failed to create a node for plugin "UVWGenModo"! Please, report this!
    VFH [Error] * Failed to create a node for plugin "TexModoLowHigh"! Please, report this!
    Thank you for your help.
    Have nice day.
    Best regards
    Daniel
    Hi, I've logged the error, thanks for the feedback.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Thank you, i just show your message i had prepare a video how i try to do , maybe it's help to fix that
      and i send you the vray scene.
      In the meantime i wish you a beautiful day,
      Best Regards
      Daniel
        just a quick question:
        i started i new project and we going to switch from Modo to Houdini,
        you know the ETA on that or an workaround ?
        just to know if it's better to redo all matirial directely in houdini. or waint until it's work again.
        Have nice day,
        Daniel
          When i used the node v-Ray Scene and import material, i have the error message but he load the shader,
          but i seem i have some broken connexion.
          I send you the schematic from modo and the result from houdini,
          Hope it's help.
          Have nice day.
          Daniel
            Hello again, we'll try to implement those ASAP.
            www.chaosgroup.com
              Ohh thank you ... YOU ROCK !!!
              best regards
              Daniel
                Hi Georgy,
                Hope you are well.
                i still waiting from the support to try the fix the download of the nightlies (strange i have all except houdini )
                i just wanted to know the ETA on this material issue. because i going next week to start to transfer my scene from modo to houdini.
                Best Regards
                Daniel
                  Hi dpotuznik , , I've talked with the sales team and they said that there is some issue with your account. You should have access to stable nightlies but for some reason you can't see them. The colleagues are working to fix this. About the "Import material" issue, it's fixed but the fix is still not merged in the stable nightlies, should be added very soon.
                  www.chaosgroup.com
                    Hi chakarov ,
                    i downloded the last build it's seem still not working ? the fix has been added to the last buid ?
                    i try to import the vray scene, it render correctly , but if i try to extract the material.it's not complitely work.
                    maybe i doing something wrong , i exported the scene from modo. i going to do more test.
                    Thank for your help.
                    Best Regards
                    Daniel
                    Code:
                    <internal> Error(3): script unknown identifier fonte
                    <internal> Error(3): script unknown identifier grise
                    <internal> Error(3): script unknown identifier brush
                    <internal> Error(3): script unknown identifier (Material)1
                    <internal> Error(3): script unknown identifier (Material)_4
                    <internal> Error(3): script unknown identifier metal
                    VFH [Error] * Failed to create a node for plugin "TexModoBlendLayersScalar"! Please, report this!
                    VFH [Error] * Failed to create a node for plugin "TexModoInvert"! Please, report this!
                    VFH [Error] * Failed to create a node for plugin "TexModoBlendLayersColor"! Please, report this!
                    <internal> Error(3): script unknown identifier (Material)2
                    <internal> Error(3): script unknown identifier abrasive
                    <internal> Error(3): script unknown identifier blanche
                    <internal> Error(3): script unknown identifier jaune
                    <internal> Error(3): script unknown identifier (Material)_3
                    <internal> Error(3): script unknown identifier noir
                    <internal> Error(3): script unknown identifier bleue
                    <internal> Error(3): script unknown identifier noire
                    VFH [Error] * Failed to create a node for plugin "TexColorCurve"! Please, report this!
                      Hi chakarov ,
                      i have found an issue, maybe it's help to fix.
                      i need to try more but maybe i have my workaround, i need to use the schematic on modo to connect all the texture and map on the vray material.
                      Have nice day,
                      Best Regards
                      Daniel
                        Hello dpotuznik , are doing everything right. The problem is that not all the modo plugins has their ui in houdini, that's why they can be rendered correctly, but the material can't be imported. I'll add this in our todo list, and we will try to do it asap.
                        www.chaosgroup.com
                          Hi chakarov ,
                          OK i understand, i think i going to redo the material inside Houdini, it will be simpler et more acurate .
                          Thank you
                            Hi chakarov ,
                            Just one question, i have this project i need to render some part under modo the other under Houdini, (see picture) .
                            i have about 20 material, i going to do today. i want to keep them simple to be able to reproduce under houdini.
                            To you think is possible to you when i finish the material to send you the file and see whitch UI is missing and add only those for this project ?
                            i think i only going to use node like "color blend" to be able mix some texture
                            ( i think i going to need that around end of next week.)
                            thank you very much for your help.
                            PS. i really like the way Chaos has to deal with update don't need to wait month to fix some bug. it's really Awsome. Good Job !!
                            Best Regards
                            Daniel
                            • #15
                              Yes you can send me the file and I can make the UI only for those that are most important for you at this moment, but still bdancer need to implement them in VFH. So I can't promise you that they will be available in next few days.
                              www.chaosgroup.com
