Nodes help cards
  • Nodes help cards
    If i try to get help/docs by pressing the question mark on the node , it will not take me to the docs but it will ask for login. And i`m not able to login there with account i normally use.
    Noemotion.net - www.noemotion.net
    Peter Sanitra - www.psanitra.com
    Noemotionhdrs.net - www.noemotionhdrs.net
    Hey there,
    unfortunately we could not figure out a way to handle this in a ... reasonable way. We have 2 options:
    1. rename the pages in the docs space or
    2. carry a local version of the documentation with the V-Houdini archive
    I'm leaning towards (2) because it will also allow us to attach examples, format the page however we want, etc. It will be beneficial but a ton of work; the formatting is completely different - copy paste from the online documentation just won't cut it.
    I hope I'll get some time to do it before an update is released.
    As to the Log in - the links are pointing to a space intended for internal use. For this reason you're expected to provide Chaos employee credentials which naturally you don't have.
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Yeah, setting up a good help/docs is not trivial task,i agree. But very much needed, specially for new users. Even veterans like me have time to time check the docs if some new features controls are added. I was looking for something on the Solid mode in environment fog settings, found it on the main docs page later, so i`m good
