GPU Image Sequence Texture
  • GPU Image Sequence Texture
    Hello,
    I made an animation of a UI in After Effects and saved it out as a .tif image sequence. I then imported it to the imageFile node as a sequence and set it to Frame Sequence. When I render out with the CPU I get the images rendering as a sequence, but when I render with the GPU, it only gives me the first image of the sequence, no matter which frame I'm on.
    Any suggestions would be gratefully received!
    Ash
