Hi
Test scene here,
https://drive.google.com/file/d/1j_U...ew?usp=sharing
Steps to produce the crash
-You will need to setup VFB history and do a quick test render to have something saved there, for example enable material override under options and set mode to lighting(just to have a quick fast render, as resolution is quite massive), now go to sampler tab and change noise threshold to .02 and do a production render
-After render is finished, click the save icon in the VFB, Now you will need to clear the frame buffer using this icon
-Now lets draw a render region and hit the play button
-Now you will need to stop the IPR, and then from the history panel click the one render you saved before
-Result, Houdini crashes without showing any messages
I recorded a video here of the process,
https://www.youtube.com/watch?v=kYHZ...ature=youtu.be
Houdini 17.5.293
Windows 10 1903
Nvidia driver 436.15
Latest Nightly
best,
Muhammed
Test scene here,
Houdini 17.5.293
Windows 10 1903
Latest Nightly
best,
Muhammed
