This might be a Deadline issue, but this same workflow was working fine during the beta. So I am unsure what has changed except upgrading to final V-Ray release. (Now running the nightly build from Sept 10th)
I'm setting up my scene as normal in Houdini. My output path is the normal <filename>.$F4.exr (also tried ${F4})
I export the vrscene, per frame, and from the Deadline Monitor I go and submit a Vray Standalone job. The jobs fails with the error
Cannot create output image file "P:/_Temp/Trond/20K/bop.<frame04>.exr": Invalid argument (22)
I've tried different paths, UNC paths and more or less anything I can think of. Still same error comes up.
I also tried with V-Ray standalone - and V-Ray for Houdini standalone (following the guides you've provided)
In Deadline you do have the option to set a new, custom output path when submitting the job. Using a single # in the file name to be replaced with the frame number.
This prevents the job from failing. Even though I write to the same location and same output name. Except it doesn't replace the # with the frame. So each rendered frame replaces the same image file over and over. There are no numbers added to the filename.
