Distributed rendering buckets don't match
  • Distributed rendering buckets don't match
    This might be not be specifically a Vray for Houdini thing but...
    Using GPU Bucket rendering and DR on one other machine it appears that one of the textures isn't loading though that might not be it. You can see the issue in the attached image, this is the GI pass but it's in all the color channel passes.
    I'm using the same vray version to render with, I have transfer missing elements on. In the vray log, everything loads successfuly and there are no errors. I'm using the same graphics driver on both machines. And I did test it once with CPU and it did the same thing. Kind of at a loss at this point... anyone else seen this when DRing?
    Thanks
    Does this happen only with that particular scene? Is there an option to send it to me?
    andrei.izrantcev@chaos.com
    Support Request
      Well, it has magically stopped happening. Apparently a good night's rest from all my trouble shooting was all it needed.
